leandro
- May 24, 2010
- Rosario, Santa Fe
- '98 Limited
Hi everyone.
I searched the forums several times looking for this problem but couldn't find anything.
I live in a subtropical weather, very hot in summer, mildly cold in winter.
In winter my X runs perfectly, absolutely no problems. The temp gauges is about 1/4 of the scale.
In summer, it gets hotter, the needle of the temp gauge reaches the water picture with the AC on, with the AC off, a little lower.
When it first start, it runs fine, but when it warms up it looses power, like if you are towing an entire house. It doesn't react, takes too much to gain speed.
I tried several things (spark plugs, injectors, fuel pump, fuel filter, cleaned the MAF, colder thermostat, replaced oil and filter for the transmission and don't remember what else), nothing worked and as summer is coming here at the southern hemisphere I started to worry again.
After a lot of reading and investigation, I think that could be the transmission, as it shares the radiator with the coolant, the transmission oil gets hot and gets too liquid. I cannot find any other possible solution, no error codes, all sensors seems right.
Any help would be very appreciated.
