BrianLJ
- June 7, 2017
- Ray, MI
- 2015 Explorer, XLT
2015 Explorer XLT, 3.5L V6, 25,000 miles. Mobil 1 5w-20 oil, Wix 57502XP oil filter. Started my explorer this morning in -15° weather, cranked slower than normal as expected but fired right up. Let it run in driveway for 15 minutes then left for work. When I returned home, I noticed a puddle of oil(yes, engine oil) about the size of a paper plate where I was parked overnight. I immediately checked the engine oil level, and it was at the full mark. I have never noticed any leaks in this vehicle before. I’m pretty sure this leak occurred at start up and not shut down from the previous evening.
No one else was in the driveway according to the wife and kids who were home from school.
Obviously I will put it on the hoist and check this out but I’m not sure when I can get to it.
Could it be a seal that leaks when extremely cold? I have a habit of snugging the oil filters pretty tight so I doubt that it came loose.
Has anyone else experienced anything like this?
Any suggestions where to look?
Thanks in advance for all the input and suggestions.
*****UPDATE*****
Started it up this morning at -5 Degrees Fahrenheit, and oil was definitely dripping down the oil filter. I usually tighten the filter as absolute tight as I can by hand. I know the seal from the old filter was not left on as I am pretty diligent about checking that and cleaning the seal mating surface. I really couldn't reach it well enough to see if it was loose. Either way I will be replacing the filter this weekend as I just changed the oil around a 1,000 miles ago.
It was not leaking once the vehicle warmed up.
Hope this was just a freak occurrence. I have used Wix filters for 30+ years. I have always considered them a quality piece and have never had an issue previously.
*****UPDATE*****
