mccoyxx
- September 15, 2009
- Belfry,KY
- 1992 Explorer 2wd
Hello everyone I need some help if you have time ... I have a 4wd 96 Sport with a 4.0 in it ... when I got it I put new upper/lower balljoints/control arms , tie rod ends and hubs and had it aligned. Well it never did stop what it was doing originally ... when its been sitting overnight or sometimes in the day too when I first pull out it has this weird feeling and I cannot figure out what it is. I pull out and its got this feeling like a flat spot in a bearing ... like I am running over very small speedbumps until it gets warmed up ... usually around 1/4 - 1/2 mile occassionally a little further ... most times not very far at all. You can feel the Ex catching on something it feels like sometimes to the point that it jerks the vehicle a little like ur very very speedily hitting the brakes for a micro second. I have noticed that the drivers side CV joint is beginning to click some in a sharp turn if I am just pulling out or backing up ... I have had the axles and u-joints on the drive shaft looked at at more than one garage and they all say everything is fine ... could it be the 4wd motor trying to engage ... possibly not enough vacuum to not keep it completely disengaged trying to lock in ? It has never locked up or anything and the 4wd seems to engage/disengage properly ... however I am unfamiliar with 4wd components as I have just gotten this ex as my first 4wd vehicle a few months ago ... any suggestions are greatly appreciated.
