indecloudzUA
- February 15, 2006
- Tuscaloosa/Hoover Alabama
- 2000 XLT 4x4
So my "stock" 00 explorer had the check engine light come on the other day while driving to work..so i stop by autozone to see if they can get the code..their scanner wont work..so i stop by oriellys and buy a scanner since i could use one anyways..it doesnt work either..it works on other vehicles but not mine..so ive tested the power and ground on the plug..ground seems okay..power is a nogo..i look in the back of the fuse box and the wire thats connected there is not the wire the schematic says should be there and its not the same as the one thats connected to the odb port..can i just run a wire straight from the battery with an inline 10amp fuse straight to the plug and be okay??im not a good electrician but i wouldnt think that would be an issue and wanted to check first..
oh, and thanks for any help!!
