Only getting hot air out of my vents | Ford Explorer Forums
defraanne
Castle Rock, Colorado
White 1996 Eddie Bauer
Hi,
I have a 1996 EB and my temp gauge on the instument cluster does not move very much after the engine has heated up. Occasionaly it moves on a hot day but is inconsistant in its readings, Usally just above the cold setting.
My AC pump is out of comission (Need new AC pump if anyone has one) have put on a shorter belt so as not to rotate the AC pump at the moment untill I get a replacement. The normal hot and cold setting on the fan/AC control will only put out hot air no matter how much I turn down the cold setting. I thinking there is a common link to these problems. My thoughts are there is a common thermostat that needs replaced!
I would much appreciate any suggestions in helping me resolve this problem.
Regards
Gordon
