G-96XLT
- June 11, 2003
- Toronto, ONT
- '96 XLT , '00 Sport
If you live in Ontario you already know they stiffened the guidelines for light trucks and the explorer owners got ####ed.
The NOX (NO) limit in Ont for a 96 EX is now 548 while some US states are 1000+ ..
I failed the test and the re-test and now I'm going to chronicle my quest to clean it up and possibly get it down below the unrealistic 548..
shocking.. the retest was much worse ..
RESULTS ***************** TEST 1 DYNO TEST
------------ limit ----- reading
HC ppm ----- 50 ----- 8 ----- pass
CO% ------- 0.28 ----- 0.00 ----- pass
NO ppm ----- 548 ----- 882 ----- failed
RPM ----- 1418 ----- valid
Dilution ----- 14.5 ----- valid
curb idle
HC ppm ----- 200 ----- 7 ----- pass
CO% ------- 1.00 ----- 0.00 ----- pass
RPM ------- 792 ----- valid
Dilution ----- 14.4 ----- valid
1 Month and 3 days have passed, I started using better gas and put in that crap called "guaranteed to pass" from Canadian tire , also shook out the air filter and checked the oil and pumped up tires..
RESULTS ***************** TEST 2 DYNO TEST
HC ppm ----- 50 ----- 13 ----- pass
CO% ------- 0.28 ----- 0.01 ----- pass
NO ppm ----- 548 ----- 1328 ----- failed
RPM ----- 1654 ----- valid
Dilution ----- 14.7 ----- valid
curb idle
HC ppm ----- 200 ----- 12 ----- pass
CO% ----- 1.00 ----- 0.00 ----- pass
RPM ----- 816 ----- valid
curb idle
curb idle
