greenstarfish20
- May 21, 2007
- Arizona
- '03 XLT
Hi everyone-
I'm so grateful to have this resource. I feel somewhat intelligent when talking to mechanics!
I've had an engine light with codes P304/P316 for a while. It starts up rough (VERY shaky a few times with engine light flashing) and then smooths out. Dealer replaced the fuel pump, fuel filter, injector, spark plug. Compression tests and wires have passed. More than once, the dealer said they couldn't duplicate the misfire and that all systems checked. But I'd get home and it would *always* happen to me. Finally I realized that my driving habits (let it sit for several days in between) might be a factor..
Armed with this new information, dealership has decided it's a head gasket causing a slow coolant leak into the cylinder. I actually believe this based on what I've read here. It also explains why it's worse when it's been sitting for a long period, right? I was hoping it was an intake manifold gasket, but I gather (from what dealer says) that it's different on 3rd generation? I don't know about actual coolant loss-- dealership tops it off-- but reservoir was half full when the problem first happened.
So my questions are...
1) is it likely the coolant leak has damaged the engine? I've been driving this way for 3 months. Some long drives in there, lots of short trips. Have never seen the temperature out of range and have never run dry on coolant.
2) if the head gasket is fixed, should I be good to go for a while, or should I be thinking about a new truck? Am I heading down a slippery slope? Would you let your daughter drive it??
