out of control | Ford Explorer Forums
out of control
CheapThrillEX
Middleville, MI (Gun Lake)
93 Explorer Sport
i just got my rig put back together, did the alignment, and man is this thing scary, its ok at slow speeds but when you get to 35 and up the frt end of the truck begins swaying side to side feels horrible, no loose parts, no loose brackets, no loose bearings, everyhting is new underneath,my alignment was set at
LF RF
-.3 camber -.6
3.1 caster 3.6
toe set to spec
i can't drive thing on pavement its so bad i feel like i am going to roll it or somethin, i don't have a sway bar on it, but my 86 B2 didn't have a bar either and it rode fine
any help please ideas
5 inch lift with all brackets, spring over axle in rear with lift shackles,
Classic symptom of a lifted Ex with no swaybar. Put it back on, and disconnect for offroad.
my b2 was lifted and had worse alignment with no sway bar and never felt like that
The BII is alot lighter. Why not put the thing on and see if it solves the problem? Seems like the easiest thing to try, and it doesn't cost anything.
i bought it without the sway bar so i don't have it, do you know of anybody who makes a quick disconnect link, i made them for my B2
picked up a used sway bar and links from the local u-pull-it and now all is well, all my handling probs are fixed
Glad to hear you fixed the problem... as RangerX already mentioned they don't call the part a sway bar for nothing.. At stock height driveability wouldn't be that bad, but the higher you lift the vehicle the more it will sway.
