Look in the "jack" compartment in the rear cargo area, on the driver's side. If you look in there towards the front of the vehicle, you will see a black or gray box. On that box will be a sticker, and somewhere on that sticker will be a 5-digit code. That is your keypad code.
This does not work on some newer models, but check just in case.
