ducrnd
- October 3, 2008
- N,Ky
- 01 xlt
01 xlt 4x4 4L SOHC. starting to overheat every once in a while.. was fine for the first 144K miles. then all of a sudden the temp climbed then dropped to regular position. about 30 miles later same thing.. First though,, thermostat is starting to go bad. SO i replaced it.. was fine for a week then same thing temp rose the dropped again.... I can not find a leak, Oil is oil, the anti freeze is anti freeze. so I dont think I have a head problem, But was told that the outer edge of the gasket may be leaking so it would blow out of the motor and fall wear ever and you may not see it in the oil or antifreeze...If the head gasket needs to be replaced,,, what the damage for something like that ??? the Cost..I mean.......
ducrnd@yahoo.com
just email me direct..if you want.
Thanks for reading it.. this trk is starting to make me very tired......
ducrnd@yahoo.com
