I enjoy this forum very much and I'm hoping someone here might be able to help me out - not too much of a car guy, but I try to use a bit of common sense and my noggin' and it usually works out ok.
2002 Ford Explorer, v6 - with somewhere around 150K on it. No huge issues - I noticed theres not much difference on the blower settings for the ac /head. It drove fine through the winter but when it got warmer outside the AC wasn't cool so I recharged it. I did notice that the passenger was cooler than the drivers side and I was just about borderline for needing another can of 134a (which I haven't put in yet)
Went to see the in-laws this weekend (600 miles round trip) to Michigan and all highway driving, not much stop and go, average speed around 75 MPH. Way up was fine, trip back home was when I started having issue. It was real hot outside and after 2 hours the AC started acting up - not blowing cool air - it came back only to go out and cycled like that a few times until I found if I backed off on the cruise control (down to around 70 from 77) the AC came back on. Around that time I noticed the temperature gauge was at about 3/4. I noticed that accelerating made it get hotter and we pulled off the interstate. We parked and I let the car cool off and then got going again, this time on side streets. Again the temp was around 3/4 but started to peg higher than that. I again found a parking spot, turned off the car and popped the hood. I checked the coolant and saw that it was even with the bottom line of the cold fill zone. After 30 minutes we left again and while on side streets to get to interstate had some jerky up shifting and temp gauge bouncing from 3/4 to 1/2 to just shy of the red mark. Back on the highway as long as I kept the car around 60 MPH we were fine but the A/C was in and out. Had to accelerate to avoid an accidentt and the temp gauge pegged in the red and check gauge came on for around 5 seconds.
Normal driving on Monday - Spotty AC and temp gauge reading about 3/4 (even after the car sitting all night and just 3 miles of in town stop and go driving.) Brought car home and let sit for 4 or 5 hours. Checked coolant level on cold engine and found it to be be a bit below the cold fill zone. Added peak 50/50 premix and brought it up to the top of the cold fillzone.
This morning the A/C worked fine but temp gauge was still around 3/4 - even after a few miles of in town driving. Parked car for around 3 hours and checked coolant - same level as last night. After a few hours of driving the car is still hitting around 3/4 on temp gaugue but A/C is not working properly. Shutting veh off and then starting fixes ac for a while.
I'm honestly not sure if my issues are related or not - is the veh just going to run at around 3/4 on the temp gauge and I need another can of A/C recharge? Should I be looking for issues with my water pump (how do I check that) or a leaky radiator (I have not noticed any thing under the vehicle.... how do I tell leaky radiator from A/C condensation?) I visually checked the outside (front) of the radiator and couldn't see any blockages
