My98xplorer
- July 28, 2004
- lakeland fl
- 1998 Sport
My Explorer is overheating! I replaced the thermostat, checked the fan, check the fluids, adn checked the radiator for leaks. The only thing i can think of is the water pump. When a water pump goes out, does it normally make a weird noise? It overheated when i wass out tonight, so i left it at a chuuch and went back about 3 hours later. It started fine, then when i was almost home it started with that noise again, then when i was almost home, the Explorer just shut off. I pulled to the side of the road and let it sit for a couple minutes. After about 10 minutes, i started it again, and was able to drive it to the entry way of the neighborhood, where it died again but i was able to coast to the house. Does the Explorer have a safety device so that when it gets too hot it shuts down? any help would be appreciated.
