BlueStreak
- August 28, 2000
If anyone has a problem overheating, I recomend replacing the fan clutch first, In trying to track down my heat problem I replaced the fan, thermostat, radiator, radiator cap, and waterpump before I tried the fan clutch. When I checked the fan clutch it seemed to work, it had some resistance when hot so I dismissed it as good,(WRONG) they cost about $30 and take 20 minutes to replace, my advice is if the answer isnt obvious, replace this frist.
hope this helps anyone else
