slravene
- February 15, 2005
- Charlotte, NC (Home) / Raleigh, NC (School)
- '95 XLT
no the two ends of the water pump did not spin free of each other...but they had almost no resistance to spinning the entire "turbine" thing. With the flick of the wrist it would spin for quite a while. The new one had much more resistance. I had removed the tstat out of the equation before i changed the water pump and it was no help.
That 192 degrees is obviously not at the temp where it is overheating. That test was a "*******" test (for a lack of a better word). We could not get the truck to run hot sitting in the shop idleing with AC on full blast. That 192 is at a little above 1/2 on the guage...driving it home it would climb to well above that, so im certain that is really of no value.
The radiator is fairly old i guess. Cartainly hasnt been replaced in the last 6-7 years. Im sure that hose water has been used some times as fluid (mixed with antifreeze). Im with you on the clog in the system, but my problem is trying to locate that clog.
