P S T suspension parts | Ford Explorer Forums
Anyone know of a better total solution than this?
what are you trying to accomplish with the kit? Is you stock stuff worn out? i honestly dont see the problem you are trying to fix.
It's completely sloppy in the front end. I know it needs new ball joint/tie rod ends, etc..
With the addition of putting urithane bushings in it, it should also make it handle better. I plan on putting a small lift kit on next.
i guess you could do that "kit" although most your slop will be cured by replaceing your ball joints you know are worn out and and adding a steering stabilizer. The TTB suspension is gonna have steering slop by the way it is designed.
