FrankT99
- April 6, 2020
- Fairfax, VA
- 2003 Ford Explorer Sport
Hello,
My 2003 Ford Explorer Sport Trac had the engine light on and gave the code P0128 and now I changed the coolant thermostat. I didn't empty the whole coolant system (was done a short time ago). I removed only the upper radiator hose to empty the minimum of cooling liquid (in a bucket below the truck).
Next step is bleeding:
I opened the radiator cap and put in a funnel. I filled it up and started the motor. After around three minutes the level of the coolant was slowly rising till it overflow the radiator exit. Also when I pushed before the upper radiator hose the coolant level rise over the radiator exit.
My questions:
1) As I wrote I removed only the minimum of cooling liquid. Is it really in this case necessary to bleed the system or is it enough to fill up radiator and tank and put the radiator cap?
2) Is this correct that during bleeding the cooling liquid is over floating and should I only go on and wait till there are bubbles?
3) Outside there are (plus) 27 Degrees. That’s a problem for bleeding?
Thank you.
My questions:
Thank you.
