P0157 code - B2S2 oxygen sensor | Ford Explorer Forums
kmarrocco
West Bloomfield, MI
2017 Explorer Sport 3.5L
Hello, I have a 2017 Explorer sport with a 3.5L ecoboost engine. The check engine light came on intermittently and the code is P0157. I understand this could be the bank 2 sensor 2 oxygen sensor. However, I am a bit confused with how that equates to the terminology they use at the dealership parts department. I went in and asked for bank 2 sensor 2 and they seem to describe them as right/left and upper/lower. Does anyone know the proper part number for B2S2? I have ordered BA5Z-9G444-A with the dealership, but I don't want to start the repair and then find out it is the wrong sensor. Any help would be greatly appreciated. Thanks!
Right= B1 = Radiator side, Left = B2=Firewall side
Corrected: Right= B1 = Firewall side, Left = B2=Radiator side
S1=upstream, S2=downstream
Thanks for the reply. I have googled the part number I have ordered and it looks like it has a grey connector. I believe it is downstream but it is described as right and left because it is used in multiple applications. I found these 2 videos and the correct part appears to have a black connector.
Does anyone have the correct O2 sensor part number for P0157 in a 2017 Ford Explorer Sport 3.5L?
Crap! I reversed the descriptions last evening for B1/B2. I edited the previous post... That oversight also caused me to look at the wrong part number...
Yes, the BH6Z-9G444-A would be the correct part number for the B2S2. The only difference in the two downstream sensors will be the length of the harness. Don't have the specifics on that. The longer harness can be used on the "short side", you'll just have to secure the extra length of the harness.
Welcome to the Forum. :wave:
The dealership is the most expensive place to parts from. Check the Tasca price against the dealer price. Also, Levittown Ford, a forum vendor, offers members a discount on parts. In this case, they do seem to be a little higher than Tasca.
Good luck and please let us know how things went.
Worthwhile to just replace them all at one time? FWIW, I have 132k on my Sport and am just now getting misfires at some throttle inputs.
I'm not sure if it's worth a full replacement or not. It might be if you intend to keep the Explorer for a longer time. According to the article, I'd say that you are approaching the life span of the O2 sensors given your mileage.
...you are approaching the life span of the O2 sensors...
There is no life span for oxygen sensors; neither time nor miles. If there were, it would be published in the maintenance schedule. Just like the turn signal bulbs, seat belts, and lug studs; an oxygen sensor should NOT be replaced unless it fails a published test.
Well.. my 2018 Sport is throwing me the P0157 code and misfiring when climbing hills.. So I think it's time.
It's time to diagnose the cause of the code & symptoms. It's never time to blindly throw part$ at a problem. An Oxygen sensor cannot cause a misfire.
Alleluia! and an Amen
