gatzdon
- July 17, 2007
- IL
- 2000 Exp XLS 4WD V6 OHV
Just got back from a 4500 mile road trip and only 50 miles from home I get a check engine light. I pull the code and get
P144C
Searching the internet seems to indicate the EVAP Check Valve or EVAP Purge Valve. At the moment, I'm leaning towards trusting this article the most which indicates that the code is for the Check Valve.
http://www.tomorrowstechnician.com/under-the-hood-ford-engines-big-things-come-from-small-packages/
I now have 49,400 miles on the vehicle and as far as I can tell, this is not covered by the emissions warranty.
Has anyone else experienced this yet? I want to make sure this isn't covered by some warranty before I clear the code.
P144C
Because of the pressurized intake system on a turbo engine, the EVAP purge system has a mechanical check valve added between the intake manifold and the purge valve.
The PCM tests the check valve each drive cycle by monitoring the fuel tank pressure sensor for a raise in pressure while the engine is under minimal boost. If the fuel tank pressure sensor reports a raise above a preset threshold, DTC P144C (EVAP check valve performance) is set.
If this code is set, the PCM may shut down turbo operation to protect the EVAP system and fuel tank from damage.
