Robert
- October 26, 1999
- Location
- CA
- Kelseyville, CA
- '13 Ram 1500 Longhorn
I'm getting ready to order a new filter, pan gasket, o-rings and valve body gaskets for my '97 4WD 5R55E transmission. In a previous post you said part # 23921 is the correct filter for the 4WD 5R55E. OK, I got that one. Can you confirm the remaining part numbers?
Bulk Parts doesn't show the o-rings for the 5R55E filter, but they do have the orings for the A4LD so I have chosen 23270 and 23271. Are these the proper o-rings for my 5R55E?
Also, the only pan gasket they show is for the A4LD. They have two listed. One is a Farpak black gasket and the other is shown as rubber & cork. I have chosen the Farpak one (23141D). Is this the correct one?
Also, with all of the talk of the bad valve body gakets I have ordered the upper (23135B) and lower (23136B) gaskets as well for an additional $6.30. What are the symptoms of a bad valve body gasket? The only thing I can think of was where it wouldn't hold 1st gear when the shifter is put into 1.
Also, do you know the Bulk Parts part number for the seperator plate (if they carry it)? I couldn't find a seperator plate listed on their site. I have the annoying whistle that I would like to fix while I have the pan removed.
Finally, my main concern is that I have had a harsh shift when my transmission shifts from 2nd to 3rd. It has been there for about 83K miles now (I have 103K on it now). It hasn't gotten any worse over the years, however recently I now get a harsh downshift when coming to a stop. It seems to happen when my transmission shifts into/through 3rd gear (just before coming to a complete stop). It is worse when the transmission is cold and will occasionally lurch hard enough to activate my ABS. For instance if I am slowing down gradually at the end of my street, at about 20 MPH, I get a harsh clunk and my brake pedal starts pulsating for about 1/2 second. The lurch feels very similar to the lurch my Wife's '93 Sable (AOD) had for about a year before we needed to rebuild her transmission. Hers however, also slipped very badly when flooring it. Mine doesn't slip at all and since it seems to be only tied into 3rd gear, I am thinking that there maybe something wrong with solenoid #2 since solenoid # 2 is only used when in 3rd gear. The only two solenoids used in 3rd gear are #1 & #2 and since #1 is used in 1st, 2nd and 3rd gear and since 1st and 2nd shift nice and smooth, I don't think it is the problem. Does this sound like a bad solenoid to you? I'm not sure if a bad solenoid can affect the line pressure during shifts or not or if the only symptoms of a bad solenoid are a lack of shifting into the related gears.
Any other words of advise?
