LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
I need to replace the power steering pump on my 2002 XLT v8. I want to replace the pump and all of the hoses to make sure the everything is clean so I don't end up with old circulating junk in the new pump. I also think it is easier when you don't have to preserve old worn and rusted parts during dis-assembly.
This is the list I came up with,
ACDELCO 36352642 Power Steering Return Hose From Rack W/Finned Cooler ($36)
ACDELCO 36352281 Power Steering Return Hose Cooler To Reservoir ($45)
SUNSONG 3404530 Power Steering Reservoir Line Hose ($7)
ACDELCO 36357580 Power Steering Pressure Hose From Pump ($20)
ACDELCO 36357580 Power Steering Pressure Hose To Rack ($25)
ACDELCO 36P1578 Power Steering Pump With Pulley ($89 w/core)
This comes to $222 before shipping with $25 back on the pump core. Normally I would use motorcraft parts but only the pump is available from motorcraft. I don't see anywhere at Rockauto where you can get a reservoir.
Is there anything I am missing on this list? Is there anything on the list that I don't really need? Does anyone recommend a different brand for the parts?
Also, does this part set,
CARDONE 3L22283 Rack and Pinion Hydraulic Transfer Tubing Assembly ($56)
replace the tubing that is welded to the rack or is this for something else?
I notice that some steering parts specify right-hand drive or left-hand drive. How would I know which is the correct part for my truck?
Thanks,
LMHmedchem
Thanks,
LMHmedchem
