Passenger Side Front Window | Ford Explorer Forums
GAZH13
Grand Bay, Alabama
2001 Sport Trac
The passenger side front window will roll down from the driver side but you have to roll it up from the passenger side. The passenger side switches work. Does this sound like the switch on the driver side is going bad? Any input would be appreciated.
Pop the master switch panel off, take a VOM/test light and see if the White/Yellow wire has power when you press the "UP" switch.(#4 in the blue connector) If not then you have a bad switch. If it does then you have a bad circuit, probably a broken wire in the door boot.
