30roadster
- January 11, 2016
- Mt Dora Fl.
- 2016 explorer xlt
Was very temp dependent ,on xlt door panel is 2 pieces . If you come right up above door speaker grill you will feel a seam/ overlap of the piece above that has arm rest attached to and the speaker grill part of panel. This seam runs front to back .These 2 will vibrate/touch and rattle under certain road conditions. You can flex the lower panel in slightly and slide a THIN piece of foam as in a mailer envelope or thin packing foam in a few places front to back of the seam. I hate rattles/squeaks, this fixed the rattle in mine, drivers door did not have problem so let well enough alone.
