Passengerside Air Bag Removal???? | Ford Explorer Forums
NAC4EV
TRUE NORTH STRONG and FREE
2010 SPORT TRAC ADRENALIN
Hi
Aside from disconnecting the battery first..
Does anyone know how to remove the passengerside air bag from the dash on a 2010 Adrenalin????? :dunno::dunno:
thanks
....May I ask why for the sake over everyone else?
Other than that, grab a torx wench and go to town on the passenger side dash. Also, the plastic covers on the sides of the dash come off easily, my driver side one never stays attached - came that way from the dealer.
At least install a 5 point so any potential passengers don't die.
Disclaimer:These current SRS's have gotten real complicated and I can't recommend you're disconnecting any part of it.If you're determined to work on it I'll pass along the instructions, for your safety only.
Four bolts for the air bag heat shield, four nuts attaching the air bag module and you're working through the glove box opening. You need to read ALL of the instructions though, including the depowering & repowering procedures. If you pop these babies you could be severely injured and it will cost you a boatload of money to replace the pieces!!!
PM me your email address or just send me an email titled AIR BAGS and I'll send you the pdf file for it.
You mean it's deactivated by the selector switch? A dealer who knowingly allows a vehicle to be released to a customer with the SRS not fully functional and free of faults is leaving itself open to incredible liabilities.
No, not the airbag, the side panel of the dashboard that is usually sandwiched between the door and dash.
Ok, that sounds much better!
Thanks for the help
I sent you my email address
