PATS code P1260 won't clear | Ford Explorer Forums
spwyso
Northern Suburbs, Illinois
07 Explorer XLT 4.0 4WD
Replaced my original PCM with a re-flashed PCM. When the PCM was powered-up, PATS code P1260 (theft detected, engine disabled) was reported. I realized then that the re-flashed PCM needed additional key programming (Type C PATS), so then decided to re-install the original PCM.
Now, the same P1260 error re-appears when the ignition key is ON. After trying to erase the code with my Actron scanner, powering-down the PCM again, pulling related fuses, etc. the error will not clear. It appears that when the PATS transceiver reads the key code (key has not been changed) and sends the data to the PCM to compare with the stored key code, the result is still an error.
Any suggestions as to how to clear this error?
Try reprogramming the keys to the vehicle, it may be freaking out because it has no key codes to work off of. That may be the only reason that the other flashed PCM would not work either. If you cannot get it to clear out then the only other person that would be able to take care of it for you would be a locksmith or the dealership.
