What are your plan's?
Are you going to replace the engine or Fix it?
My rear guide broke and caused the cam to jump timing on that side. I pulled the engine and then found the main and balance shaft guides broken. The left cassette was the only one with no damage.
I'm only saying this in case your going to fix the engine yourself and plan on not doing a complete inspection of pulling the front timing cover.
I will say this. It's probably cheaper to replace the engine , specially, if bent valve are included as in my case. The problem with getting another engine,.. probably with as much or mores miles on it is that you increase the change of also getting an engine with bad chain guides. At least fixing it yourself you know the guides are fresh.
CJ
