SGF
- January 12, 2002
- NC
- 1994 Eddie Bauer
Pinging problem solved
There have been numerous discussions here and elsewhere about the pinging problems many Explorers have. My 94 had the problem and it wasn't solved by cleaning the MAF sensor or some of the other suggestions that have helped others. The only thing that would stop the occasional pinging was higher octane gas. For the most part I ran regular 87 octane except when pulling loads or on trips to the mountains, since the high test is so expensive. For normal driving I would just keep my foot out of it to eliminate or reduce the problem.
My pinging is now gone so I figured I'd share what happened. I realize it may not work for everyone but here it is.
I recently began experiencing a hesitation when accelerating. It was almost like someone would squeeze the fuel line for a second. This vehicle never did that before and ran great (except for the ping) so it was all the more noticeable and it quickly got worse over the course of a week.
I brought it to a shop I've dealt with for years and they put it on the computer. Apparently a sensor failed which caused other equipment to go bad. In my case the MASS air flow was shorted and the MASS airflow sensor and IAC were bad. The EGR system was plugged with carbon. I guess that isn't too surprising with 195,000 miles on the odometer. The following is the list of items that were replaced. It cost me $734.00 because these sensors are not cheap. Most of the cost was for parts.
Because of the expense it's obvious that the solution isn't to replace all the parts unless it's necessary. The good news is the computer may be able to read your equipment as failing before it does more damage like mine did.
Here is what I replaced:
OEM DPFE sensor for EGR valve
OEM IAC motor (idle air control)
OEM air flow meter
OEM EGR valve
OEM vacuum control valve
MASS air gasket
EGR valve and sensors (also cleaned ports)
I hope this helps someone to fix the problem before the cost skyrockets.
SGF
OEM air flow meter
OEM EGR valve
MASS air gasket
SGF
