Pinging in 91' Help! | Ford Explorer Forums
ExploderBlues
Cathedral City, CA
1991 XLT
91' pinging.....doe's this model year have a knock sensor, and if so, where is it located? Does it more in overdrive, as opposed to Drive, but still does it and more when going up a hill or into strong headwind. Between 55 and 75 miles per hour, any suggestions?
Your lower intake bolts probaly need retorqued.Do a search there is tons of info on this subject:D
Is the pinging the same as "rattling" valves under acceleration?
Thanks,
KevinK
'91 XLT
91's don't have the knock sensor. I think that was added starting in 95. Re-torqueing the lower manifold bolts can fix it sometimes. Last time I tried re-torquing them I had trouble getting to all the bolts (you'll need extensions etc). You might also clean your MAF sensor. Do a search on that, and there is also a write-up with nice pictures on how to clean the MAF here as well.
