Vinnie P
- August 29, 2002
- Windham NH
- 95 XLT
Replacing the shaft on the rear end after an e-brake shoe change caused the side gear to be pushed out and the pinion gears to fall out. I know it happened because the spline wasn't lined up (my son and his friend were doing great until they tried to force the shaft in without aligning the spline). And now with the side gear back in I can rotate the upper pinion gear in but not the bottom one. I tried a search with no luck. Need help!
