well,
where is the best place to put the end of the new leaf?
Where it is in the mock up photo,
or will it be better to move the leaf back more to the rear and have the new leaf sit on the longest leaf only, about 4" more to the rear?
helper springs are used to increase payload capacity, they will make your leaf pack had to compress and def limit flex if you tried to off-road with them....and if you want to insatall that properly it needs to be centered under the axle tube
is there a sticky on or could someone enlighten me on how to do the spring over conversion? That is just moving the leaf springs up over the rear axle right? How much lift will I gain and can I do that by myself at home in the garage? What other steps should I take in addition to the spring over move?
