Please... Atlanta Mechanics / BELT help | Ford Explorer Forums
2000EB4x4inGA
Atlanta Georgia
1997 Limited 4x4
Please... BELT help assuming its Tentioner
Ok had a new belt put on my X. Now when i touch it, it is lose to the touch...plus the alternater isnt charging....etc.
I cant tell if the belt wasnt puit on correctly or if the tentioner went bad suddenly... but basically i am screwed unless i can either
A. fix this myself
B. find someone to fix it tomorrow (sunday) here in Atlanta.
If you know anyone or can help me get this thing i would really appreciate it.
Thanks Guys
Brian
Find the tensioner and try moving it around... It has a heavy spring and should only move if you place a large socket on it. I now the belt is new but how does it look? I had a buddy's AC compressor start to go in his blazer (bearings... Basically this had the effect of the AC pulley causing an increase drag on the belt which slowly trash it.
Ok belt looks good. I can take a digital picture of this area but what i need to know is this...
1. My Belt is the loose but in good shape on the pulleys.
2. My tentioner is still there BUT as it moves in a clockwise motion it is alrady 100% to the left say at a 9 or 10 o clock on the face of a clock.
3. Will i need a breaker bar to get this off?
4. What size belt should i have? Is it possible they jut put too large a belt on?
5. Can i get a belt on my X in parking lot without any tools except a socket wrench and a screwdriver... i have limited means since i just made it to a friends house before losing my power steering... better than needing a tow though.
6. When i tried to move the tentioner it wiggled a little but i dont yet have a socket to put on it.
Thanks in advance
Brian
On my 1st gen I just need a large socket wrench or breaker bar on the tensioner and I can slip the belt off. It is possible they installed a belt that is too big, does it have any #s on the belt to help id it?
There are 2 sizes of belt, each a half-inch different from another - that half inch difference may very well be the culprit, as the tensioner cannot compemsate that much. (I did that once myself on my 91....)
