please check my math | Ford Explorer Forums
97ExplorerV8AWD
North Port FLA
97 Explorer
If a Cobra R rim is 17X9 with a backspacing of 5.95 inches then a 17X8 wheel with a backspacing of 4.95 inches would give a similar stance, correct? I figure if you have a wheel that is narrower by 1 inch deducting an inch off the backspace should out the outer edge of the wheel in the same plane with the trucks body.
Also if Rs have an offset of 24 mm, how is the backspace 5.95 inches. I figure 0 offset on these rim would be a backspace of 4.5 inches, add 24mm which is less than an inch and you get a backspace of less than 5.5 inches, right?
Thanks for the checkup, Jason
lots of lookers, no takers
Your right as far as the first paragraph, but you lost me on the second one. Oh well I am a little tired, but what you said in the 1st paragraph was true. I think...:)
