Another Update...
Saturday.
The vibration/shudder is getting worse and is now noticable in OD.
I installed the rebuilt valve body last night. The trans shifts flawlessly. I believe my original OD problem is solved as well.
The OD band is adjusted to 1 1/2 turns. I tried setting the intermediate band at 1 1/4 turns but it made no difference.
There were no metal shavings in the pans to speak of. There was one small pile of shavings in the bottom of the pan about the size of a squashed pea. There were no shavings on the magnet.
The shudder/vibration is still there and it seems to be getting worse. Here's how it acts:
Revving the engine in neutral - no vibration.
While I had the car up on jacks last night I ran it in gear - no vibration.
I put the car in 1, held the brake, and floored the gas for about three seconds - it stalls at 2600 RPM and no vibration.
1st gear. No problems at all.
When the vehicle speed gets to 25 mph the vibration begins. It seems to correspond to the shift to 2nd but I can't say it does all the time. The vibration frequency starts off low and increases as vehicle speed increases.
Prior to yesterday I only felt the vibration/shudder in 2nd gear. Yesterday I began to feel it in third. Today I can now feel it in OD (4th) too.
The vibration is a much higher frequency in OD as the vehicle speed is higher.
The heavier the load (accelerating, pulling a hill, etc.) the more intense the shudder/vibration becomes.
If I let off the gas and coast - no vibration.
If I put it in 2 while driving I get engine braking. No vibration
Under 25 mph it's smooth as silk. 25-35 mph low frequency medium intensity. 35-55 intensity stays the same but frequency increases. 55+ low intensity and high frequency vibration.
I'm really starting to think this has nothing to do with the bands or clutches and maybe it's some internal spinning component out of balance. What do any of you think it could be other than the bands/clutches?
The torque converter is a rebuilt unit that I put in while I had the trans out. If it were the torque converter out of balance wouldn't I feel it in neutral too?
The vibration/shudder didn't start until 2 1/2 days after the rebuild.
This is getting ridiculous.
