Please Help losing oil pressure | Ford Explorer Forums
harleyd
el dorado, arkansas
93 sport
recently my explorer ran hot, blew radiator hose, now when i crank it up i get oil pressure, but when i get rpms up i lose pressure. i drop rpms and get pressure back. seems to worsen the warmer the engine gets. any ideas what may be causing this?
If your engine overheats you will lose oil pressure. Did you fix the problems with your radiator, or did you just replace the blown hose? You need to find why your car was overheating and fix it, if you continue to have low oil pressure it could be your pressure gauge or you oil pump.
