bbmoose
- February 2, 2004
- PA
- 2000 XLT
I already posted here that i was having headlight problems.
Well i got the headlight stook and installed it.
Well i had lights but the wipers would stay on high no matter what i tried.So i got the new harness and VERY CAREFULLY wired it in 1 wire at a time.
Still the same problem?
Reconnected the old and no headlights but wipers didnt stay on(they worked like they should normally).
Well after 2 hrs i got the wipers to work correctly with the new stick but now i have high beams on all the time,the rubbing lights work normally but you cant get headlights to work without the key on,if you start the vehicle the highs come right on BUT i cant select low beams?
I checked all the fuses(under the hood and drivers door), could a relay be bad now?
If not any ideas.
PLEASE HELP
If not any ideas.
PLEASE HELP
