LoriB05
- November 21, 2014
- Pensacola, Fl
- 1997 Mercury Mountaineer
1997 Merc Mountaineer - have the coolant leak issue - realized was coming from 90 degree elbow hose aka bypass hose. Pulled off today to replace and was actually the valves hose plugs into. Valve against block came clean off! And one against water pump is a stub with flat piece of valve that used to be there earlier and has holes in it. Are these plug in valves I can get to replace them with? Or do I end up replacing the water pump and whatever piece this is against the block to have the valves back to plug bypass hose into? Help! Lol I am a female and doing excellently to have gotten this far and half know what I am talking about. I am freaking out this is my only way to go and now I am stuck
