Changing the plugs is quite simple. I changed mine a few months ago along with the wires and it only took me about 45 minuets. All you have to do is pull off the plastic skirt behind the tires. When the skirt is removed, you will have a straight shot to all of the plugs. To remove the plugs, it would help if you have a socket swivel and extension. When removing the skirt, pull hard to pop off the retaining clips. Good luck
