Mike65
- December 31, 2013
- Horsepasture, Virginia.
- 2005 2WD Regular Cab F150
I dropped the fuel tank to replace the electric fuel pump on Jan 12th & it has run fine up to this past week when it tripped the CEL with a PO 455 code Evap system gross leak is what my scanner is telling me. My wife tells me the truck is running fine no rough idle, no stalling, or loss of power, just the CEL is on. I cleared the code & in a couple days it is back on. I had the tank down to replace the electric fuel pump, & removed the fuel filler neck to replace the fill & vent hoses. When I put the tank back up I did remember to re-hook the vent hose to the valve on the top of the fuel tank. Today I am going to pull the filler neck out & check it for any cracks or rust. Any thing else I could check?.
