PO122 error code and more!! | Ford Explorer Forums
markedman450
Enola, PA
01 Sport
Please help! I have a 01 Explorer Sport. Was running really good when the check engine came on. Had the code pulled and it was the PO122. It did idle a little rough(new plugs, wires, distributor, cleaned MAF, etc) so i got a new TPS and a New Idle Air control valve. Left the car unplugged for an hour, started up seem to run fine check engine light off. Took it out for a drive and uh oh....Car when i stop idles around 200k and almost stalls, even causes gauges to flicker like its stalling. Also its lossed power and check engine light came back on. If im trying to accelerate it accelerates slow and even if i floor the pedal it doesnt down shift or anything just keeps slowly accelerating. Any ideas...? Could it be a bad harness? Some other sensor...
