wicsmith1997
- May 6, 2010
- Darlington, SC
- 97 XLT, OHV, 4x4, auto
My Ex-Father in-law whom I get along with well informed me he hears a kachunk noise every time I go down his driveway and for every pot whole I hit. After 5 - 10 minutes of jumping on the bumper and shacking the vehicle at park was finally able to reproduce the sound.
If you put your foot on the receiver ball and push it toward the tire opposite the side your on and grab the wheel well and rock the vehicle side to side it starts to make a metallic popping sound which sounds like its coming from behind the wheel rim.
Best way I can describe this sound is if you've ever had a thin piece of metal that had a concavity to it and you was able to pop that concavity back and forth that is similar to the sound I am hearing.
Our guess is its some play in the Axle. Does this sound correct to you all? Does it sound normal?
1997 4.0L ohv 223k miles, 4x4 with control trac
Vehicle seams to run fine otherwise, Strait no sensation of drifting while driving. No odd rumbling noises while driving.
Any helps or suggestions appreciated.
