post-body lift concerns | Ford Explorer Forums
ExporeRanger
Highland, Md
92 XLT
everything seems to matchup and look fine to me except theres a considerable gap between the rear lip and the top of the rear bumper..its unsightly, which i dont mind too bad i will make a cover for it if need be..but the front bumper lines up perfectly and meets like stock..so im wondering if there was a lapse in something there..
also..i've heard tales of the steering working better without the steering ext. i did install mine..and its great goin straight and curves, but on tighter turns, its resiliant..and then it seems to let up then become tight then let up and become tight again as i am turning it..is this normal"? should i be concerened..is this somethin that will "looseN" up over time?
thanks
-chris
as for the bumpers, thats the way they pretty much are you can wither leave it or add a piece to make them flush.
As for the steering, it sounds like the u joint is binding, I would def check it out and maybe its time to replace your steering joint.
im pretty unfamliar with the steering setup..what "joinT" is this?
