josh_ruppert
- January 5, 2002
- LUDINGTON, MI
- 2014 Explorer Sport
Hello everyone,
It has been a pretty busy few weeks but I have the Explorer Sport back together and driving. The vehicle runs decent but appear to be experiencing some issues.
I do feel a surge when accelerating. Sometimes is worse than others. At WOT, it will surge, as if power is being cut in and out. Once I get to around 65, it wants to hang there for a few seconds before shifting and struggles beyond.
I pulled codes and I get a P0234. On a long drive, I will also get a P0430.
For the P0234, I have inspected the vacuum lines. They are all connected. I have also swapped out the boost solenoid. This has not corrected the problem. I need to pick up a vacuum gauge to check to see if the wastegates are moving properly.
I have attached one freeze frame that my Forscan produced from the P0430 code. One thing I am noticing are high (positive) long term fuel trim's around the 14's. I have inspected for vacuum leaks so this leads me to believe it is a fuel related issue. I am aware that a bad or dirty MAF can cause numbers to be off, which is why I ordered the inexpensive MAP just to rule out.
For the P0430, I am not sure what to make of this. It is a new C.A.R.B certified converter. I am kicking myself in the butt because I did not replace the o2's during this project. The front downstream was replaced due to a bad connection. I may purchase new Motorcraft's and install. Just not liking the idea of throwing parts around.
Any thoughts?
Any thoughts?
