Power antenna | Ford Explorer Forums
Power antenna
aldive
Elite In Memoriam
1999 XLT
Are there any output leads for controlling a power antenna on the factory head unit?
Has anyone added a power antenna?
Thanks....
You could probably splice into the existing radio's remote line lead if you could identify which one it was. This site may help you:
Dead Link Removed
The problem seems to be that Fords have a 5 volt turn on signal rather than the 12 like most other cars and components. Because of this you'll need to go out and get a Low Voltage Trigger too. An inexpensive piece you can get from Sounddomain.com or anywhere else, I'd figure.
Hello,
I installed a power antenna in my 96 XLT. Go here to read the post about my installation:
http://www.explorerforum.com/forums/showthread.php?threadid=23022
Installing a stock power antenna is difficult if your truck didn't originally come with one because you'll be missing the harness and the power antenna control module.
I haven't had any problems with the J.C Whitney antenna.
Carter
Dead Link Removed
WOW, that's one hell of an install!! I am looking for something like that, only two 12` subs, not FOUR!!! LOL my god, that guy must be hard of hearing, I know I would be!!
