Power door locks cycling - Coincidence or not? | Ford Explorer Forums
ColoradoZ28
Monument, CO
1998 Sport
98 Explorer 2 door with 5 speed manual transmission, 190000 miles. The other night I started having the problem where the power door locks will continuously lock. Now all I have to do is lift a door handle (either door) from the outside and it will start cycling automatically. I found if I use the key to lock the door (with the door opened or closed) the cycling will stop. I've pulled fuse 18 from the interior box to avoid the problem, but now I have no power door locks. Based on what I have read in this forum I will be looking for a bad connection somewhere.
My question is whether or not I might have caused this with a recent repair since it started right afterwards. I replaced the clutch master cylinder which required me to move the under hood power box (no wire disconnectons and the battery was disconnected) and work under the dash. Getting the master cylinder in is a little tight and I'm thinking I might have damaged some wiring. However, I'm not sure what wiring may have been affected by working in those areas. I'm looking for suggestions from the forum. I have looked at the wiring tunnel into the driver's door but it appears to be OK.
I had the same problem with my 96 XLT. I found the cause to be from running the battery down while working inside with the door opened. I don't know why that would run down the battery, but that seems to be the case. Long story short, be sure battery is charged, go through the door lock sequence in the owners manual, and you SHOLUD be OK
It is UNLIKELY that its a problem in the driver's door "wiring"... IF you look at the numerous posts (some with pictures), you will see that it may be a "potentially" problem splice in the rear driver passenger area..... BUT as suggested you might have issue with the module itself "cycling" for various reason. My guess, a splice problem... you can also try to "unprogram" the "autolock" feature just to see if that helps.
