Power Lift Gate Does Not Open All the Way | Ford Explorer Forums
isstatu1
Mullica Hill, NJ
2016 Ford Explorer Sport
I'm having issues with my power liftgate. It does not fully open. Or at least I believe it does not fully open. When it opens I still have to push it up for another 5 inches. I've reset the height adjustment multiple times using the button, but it still doesn't extend all the way up. If I program it at a lower height then it stops at that height, so it's not a programming issue. I'm about 5'10" and it stops right around my forhead. Could it be that the actuator might have to be replaced?
Usually, if it is the liftgate motor/actuator, the liftgate won't open at all. Using the handy 'Search' feature (top right) I found a thread with a previous post of mine that may or may not help. 2018 Explorer Platinum Liftgate won't fully raise
Make sure in setting the height that you hold the liftgate up all the way (or to the point you want it to open to) and hold the button until you hear a beep (maybe it's a chime). If this doesn't work then time for further diagnosis but as Peter said above, unlikely to be the actuator.
It does beep, but still doesn't open up fully. If i were to program it to open up less then in programs fine. But then I open it up all the way and program it to fully open and then it stops a couple inches short.
Is this a recent development or has it always been like this? I always set mine so that I can open it in the garage without hitting the open garage door.
I recently bought the car like that. So no information on previous behavior
I've borrowed a scanner and initialized the tailgate. That fixed the issue. Thank you all for your help!
When you say borrow a scanner, what do you mean?
Welcome to the Forum Eric. :wave:
One thing I didn't mention to isstatu1 was to try and open the liftgate all the way and press the liftgate button until it chimes to reset the height memory. The previous owner of his vehicle may have set a lower height like I do so I can open it when it in the garage.
i can set it to any height lower then the point it is stopping at now but any time i try to set it fully open it goes back to 6"-12" below
