jonagne
- July 5, 2005
- Maine
- '97 XLT
INITIAL POST:
I've been having the same problem intermittently for about a year. '97 XLT w/ 86k. It almost always happens after driving on the interstate for awhile (30-40 miles, although last week it waited until 175 miles). I first noticed it when accelerating out of a toll booth, and had no power at all until I pressed the pedal all the way to floor, at which point it downshifted and started to accelerate normally. Last week I had the cruise set at 70, and when climbing a hill (not a steep one) it decelerated all the way to 55 before downshifting and accelerating back to 70. The cruise steadily moved the gas pedal almost to the floor. The engine sounded like it was bogging down as if I was in too high a gear. The CEL light flashed on/off 4 times and remained on.
I initially thought it was a transmission problem, but everything checked out perfect (plenty of fluid, good color, etc.). I was starting to suspect a bad engine computer as this is sort of what happens when mine went on an '89 Volvo, but isn't that usually an all or nothing event?
Maybe I'll change the O2 sensors, and/or take a look at the CATS (I'm assuming catalytic converter). Of course, the Ford dealer is clueless, so any further information would be appreciated.
Finally had a chance to get the codes:
P0305B: Cylinder 5 misfire
P1151
P0153B
I'm going to follow the advice on other threads and clean the MAF and IAC and see what happens. I'm a little concerned that the misfire might be an injector as I just replaced the wires and plugs 6,000 miles ago.
Any other advice will be appreciated.
P1151
P0153B
