Power Points/Cigar Lighter Question | Ford Explorer Forums
Noobie
2004 Explorer Limited
In my 2004 Ford Explorer my owners manual has under dash fuse box labeled as fuse #2 4 rated at 15A and calls it "Cigar lighter, OBD II, Neutral tow". The manual alos has in the under hood fuse box fuse #7 as Power point #2 and fuse #9 as Power point 1 both rated as 20A. My question is I only have two power points (that I see), one in the center console in the front of the vehicle and one in the rear compartment of the vehicle.
What would be fuse #2 4 rated at 15A and called it "Cigar lighter, OBD II, Neutral tow"? Is it some addtional add-on with some kind of smoker's package? Why would then also have a power point 1 and rated at 20A.
I ask because I need a 20A power point and am not sure if what is in my center console near the cup holders, i.e., is it the 15A Cigar lighter or 20A power point #1 .
Thanks in advance.
The cigar lighter/ashtray was an option. The 2 you see are the 20A fused power points.
rrgone and Number4 thank you for confirming that. I was looking at a portable compressor and many reviews noted that you need a 20A outlet. The owners manual seemed to indicate that what I have are power points at 20A, but I wanted to make sure that the front outlet was not a "Cigar lighter" which the owners manual rates as 15A.
Seems to me the front power point is only 20 gauge wiring. Some Ex's might have a power port in the passenger rear qrtr panel, right there when you lift the hatch. That one has something like 10 gauge wire.
