Cigar lighter not working. | Ford Explorer Forums
66stingray
2002 Mountaineer
My auxiliary cigar plugs front and back are not working. I checked the fuse, I believe it was #24 and it looked fine. Just to make sure I did a continuity check on the fuse and it checked out. I took the console top out and checked the wiring and didn't see any problems. Im not getting any power at the leads for the cigar plugs when I checked with a tester. Any other ideas?
I have my rear parking sensors not working and probably have one sensor that needs to be replaced. My Haynes manual doesn't show the wiring schematics for the parking sensors or the cigar lighter which I thought was odd. Could the two problems be related?
Also a second fuse #35 (20A) for the rear power point. (Page 213)
Thank you, both fuses were blown and now with replacements the ports work. Whats strange is that I noticed I am missing the #35 fuse for the rear power point. I never took it out in the past, do I need it?
If it's working then no.
Odd both would be blown at same time. You must have a bad device that blew one then you tried the other plug and blew that one too.
