Power steering leak. | Ford Explorer Forums
explorer83
JACKSONVILLE,FL
02 Ford Explorer
Alright guys narrowed it down to leaking at the plastic housing.
I pulled it off cleaned it up and reinstalled and still leaks what am I missing here guys?
Sorry guy it is a 92. And it is the plastic housing that mounts on the back of the pump it is two separate pieces
Lucas power steering stop leak
This stuff is thick as molasas. It does work. Make sure you drain enough of your old power steering fluid to make room for this stuff. It's like $9.00. It quits it down a bunch also.
Okay guys found the problem. While on vaction took it back down and found a o-ring that mounts on the pump and seals the plastic housing to the pump, replaced o-ring and now no more leaks.
