SwissEric
- November 22, 2002
- Bursins, Switzerland
- 92 Explorer 4.0 litre
A friend of mine is bringing me his 1992 Explorer w/ 4.0 litre engine for a major service. I will be changing all the fluids; engine, transmission, brake, antifreeze and power steering pump. I have gone through this great forum and have already gotten almost all the "how to" information I need, particularly on changing the auto-transmission oil, but I haven't seen anything on the p.s.pump.
Some questions; what is the best and easiest way to completely drain/flush the p.s.p? Is it possible to use the same principle of the tranny by disconnecting the pressure and return lines, or do I just drain the pump and reconnect the line and fill it up again.
I would like to make sure all the old fluid is flushed out of the p.s.p. and not just what is in the pump.
Does the p.s.p. use the same ATF as the tranny or does it have special Ford fluid? How much fluid does the power steering circuit hold altogether?
Tranny question; The tranny slips when cold but works fine when warm. The fluid is brownish red but not burnt (just old, I think). Will a new filter and completely flushing out all the old fluid cure the cold slippage problem.
I am writing from Switzerland. The Explorer is not imported here so we had to order the tranny filter and gasket from the US. I think that without this website and forum I would have turned down the job since the local Ford people know nothing about this model that was bought in the US.
Thanks for your help.
