power windows not working | Ford Explorer Forums
betoschulze
2004 Explorer 2wd xlt
My front driver side and rear passenger side windows are not working.
Front passenger and rear driver side windows work fine. I hear a little click in the rear passenger side when I activate the switch in the driver door.
Any idea?
Can you operate them from each door?
no, can't active the front driver side window and the rear passenger window from the drivers panel. Also can't active the rear passenger window from the rear door panel.
All other windows and switch panel work fine.
look in the wiring harness in the drivers' door for broken wires. The drivers' door switch is the master switch and usually if some windows work and some dont there may be broken wires in the drivers' door harness. Had a similar problem in mine with a passenger window not working ended up being a broken wire in the drivers door harness. open it up and take a look. soldering them back together is tricky and takes some patience due to limited access but it can be done.
